Gen 1 OEM Fox Shocks
Knight
I'm in Texas near Shaun Miller and interested in buying to replace my kings. Willing to budge on the price at all?
Sent from my SM-G935V using Tapatalk
SVTLOPEZ
SVTLOPEZ
Rears are sold! I still have the front available. PM me if interested. Thank y'all for the interest
trophycummins
Simi Valley, CA
The top bolt pattern is different on the coil overs, but the LCA mount should be the same. You need a set of '17 Raptor take off coil overs for all 14+ F150s. The rear shocks I'm not familiar with but I don't think it would be any different.
This is incorrect.
The top bolt pattern is the same. Gen1 raptor to 15+ F150
LCA mount is different Gen1 or Gen2 raptor to 15+ F150
'17 Raptor take off coilovers will not fit into any F150 even with raptor suspension due to length.
You could run Raptor arms with Gen1 coilovers on a 15+ F150 and it is widely done.
Rear shocks bolt in, Gen1 or Gen 2, into any 4x4 F150.
SVTLOPEZ
SVTLOPEZ
This is incorrect.
interesting!
BC119
CT
This is incorrect.
So you're saying LCA Gen 1 = LCA Gen 2 = 09-13 F150 but not equal to 15+F150. (they changed something in the 14 F-150 coil overs so it should be 14+)
and top bolt pattern Gen 1 = 09-current F150, so the Gen 2 Raptor has a completely different top bolt pattern than any other F150 made?
The Gen 2 shocks don't fit due to length?? even with Gen 2 UCA, LCA, steering knuckles and axles? Gen 1 shocks don't fit on a non-lifted or Raptor suspension converted truck either due to steering knuckle length.
trophycummins
Simi Valley, CA
1) I never said they were equal, I just said you could use them interchangeably, you would need the rest of the suspension from that Gen1/Gen2 setup.
2) I never said the Gen 2 had a different bolt pattern. Just that the Gen1 bolt pattern worked with F150's.
3) Yes, the coil buckets are at different heights. Yes, the Gen1 shocks fit on "Raptor suspension converted trucks"
My 17 F150 has Boxed arms built for a Gen1 Raptor, With Gen1 King 3.0's on it. We have installed Gen1 arms, using 15+ knuckles, with gen1 OE coilovers.
