Geiser Springs and +3 Deavers installed (Pic)
BlueGoliath96
Looking good What’s the height of the cab ? After the lift upfront and rear
T
Tlh235
you want from the ground to the top of right above the drivers side?
---------- Post added at 12:19 AM ---------- Previous post was at 12:13 AM ----------
it looks to be right around 81
TXRaptor
Got the Geisers and Deavers installed on Monday. Did some measurements. I measured from the ground, somebody mentioned that i should actually measure from the bottom of the wheel...so take my measurements with a grain of salt
The 3/4" difference from back to front is the same amount of rake I have on mine. I think it is a perfect stance for our trucks!
Now, you need to grab some 37s and toss them on! :biggrin:
BlueGoliath96
Yea I mean from the ground to the highest point of the cab at the back near the Bedsides [emoji1320]
cao0215
looks really nice. have you order any aftermarket bump stop pad for leaf springs?
murph145
Simi Valley, CA
Your back should settle more. I have the same set up as you do and my back and fronts are exacxtly level @ 43 1/4"
Once you go offroad a little or carry a load in the bed the rear leafs will drop down a bit more. I was kinda worried at first when I had mine installed but am super happy with how level my truck is now.
TXRaptor
Yes, he should see some settling. After checking mine, I am at the same height as his *with* my 37s. 43 1/4" front and 44" in the back.
Jeff-Ohio
Cincinnati
Please give me an honest and unbiased opinion on my questions below.
1) How does the truck ride now compared to stock with respect to stiffness? If I had my pick, I would actually like to slightly soften the factory ride, so would I be happy with the changes you made?
2) What did it cost to do your upgrade?
3) Did you have to make any other mods to keep the 37" tires from rubbing?
