Trick.Raptor
The Cracker Raptor
What bump system are you referring to?
SVC Gen2. I spoke with Jarrett and he said he won't receive Fox or King's until early Jan. so he is backed up right now.
Went with mid perch due to only having time to install them once. Should have gone bottom perch. Your going to gain an inch if lift out of these springs. Now I got some sweet cali lean going and the front end rides like a 2x4. On the upside The truck rode great with stock springs on mid perch and replacement rear leafs.![]()
I like a bit nose high to but this is a little excessive imo. I'll drive it around for a couple months then drop it down no biggy.
@Turning Blue thanks! I bought some used sd nationals off of a local guy. It's almost 2" higher in the front I only want about 1", so lowering to bottom perch is exactly what I want. @Crikk 37ko2s and 17s on your truck mid perch fosho!
