Gear display
chrisk2361
Anyone know how to get the gear display on the dash to come on. I had the truck in the shop to replace the oil pressure sensor. When I got the truck back, the gear display is no long lit. Hope it is something simple. Thanks
NASSTY
ME
Push the + button on the shifter...or hit the + paddle shifter.
JetDriver480
They likely tapped your + Paddle Shifter while reaching around in there. That will make them go away. As mentioned just hit the + Shifter and you are back in business. This topic comes up a lot so you are not alone.
sphf250
Maryland
I was just having the same problem the last few days. Thanks for the info guys, problem solved.
