Garage fitment
NHDude4
Southwest, NH
Measure your garage and look up the dimensions. It's a real thing that it might not fit. My garage is fairly small. I have an inch of roof clearance and while it will fit with the mirrors out it's close enough that I fold them when entering and exiting to make things easier. I also only have 3 inches of clearance at each bumper, so I need a reference to park it on the spot.
KOBRA2848
Mine fits no problem parked next to my Shelby. There is no getting in the passenger door while in the garage. I did have to shorten my antenna because I got tired of it hitting.
Mark
The Real Coolbreeze
Oregon
I'd say. "Don't measure the hole! Measure the opening because the door droops down a ways!!!"
Luckily it had some rubber gasket material on the bottom edge of the door when she drove the old..... never mind......
NHDude4
Southwest, NH
Also make sure when the door is open there are no parts of the door that hang down lower than anticipated. Measure it in each configuration.
DanT
North Texas
A9C07317-10D7-4FF1-A759-DC3A323CD4B6_1_201_a.jpeg standard height = 6'7" on level ground. Mine fits height-wise. Length - only backed in and have to remove my bumper-step (weathertech). Damn builders cutting cost by shrinking garages - prior home build in 1989 could fit Expedition and volvo 745 wagon, walk around cars and easy entry. Current home build it 2004 - have 3/4 clearance between door and from grill - no walking around...also will be extremely tight with another vehicle.
Braaaaptor
Starbucks Enthusiast
The drive-thru
Nearly snapped the OEM antenna the first time I tried to fit it in the garage so a stubby antenna was the first mod I made and then I put a curb down to protect my wall.... It's a whole 'nother level when you start modifying your house for your Raptor.
NHDude4
Southwest, NH
Haha nice. I'm not that tight but that's a great idea. Should get a curb so I can just pull in till it stops.
Braaaaptor
The drive-thru
My problem is that I have to suck up so close to the wall that I can't see the ground in the rear view camera and I knew it was a matter of time before I over judged it by 3 inches and there goes the wall and my bumper.
