For fogs that you plan to use for general/street use i'd recommend the following:
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights-sportsmen/
It's the Sportsmen kit. You get a lot for your money and lights that will give you just enough for those dark roads while not breaking the bank or going nuts.
One other option would be the Build Your Own Kit here:
https://www.4x4truckleds.com/2017-f...ght-kit-w-baja-designs-lights-build-your-kit/
And go with:
Squadron SAE Wide Cornering
Squadorn SAE Wide Cornering Amber
Squadron Sport Driving/Combo
That'll give you white and amber lights for road use and then the driving/combos can be used to light up back-roads (you can also upgrade to the Squadron Pros for a bit more light)
Upper Grill kit would be here:
https://www.4x4truckleds.com/baja-designs-ford-raptor-2017-30-s8-grille-led-light-bar-kit/
Lower Grill kit is here:
https://www.4x4truckleds.com/baja-designs-ford-raptor-2017-onx6-lower-grille-led-kit/
Now all of those products I listed are 100% bolt on and include EVERYTHING You need to get going. From the brackets and lights to harnesses and hardware.
As for impacting airflow and ACC, no impact at all. The only impact would be the lower 10" grill kit WILL sit in front of your factory IC but nobody has ever complained about issues. If you are in a very hot environment and drive your truck hard you MIGHT want to skip on the lower 10" kit. Otherwise if you're doing regular driving and not racing around ALL THE TIME in hot environments, you're good to go, no worries at all.
The ACC module is behind that black plastic cover on your driver side. Nothing gets in the way of it at all.
