Sasquatch77
Banned
- Joined
- Feb 25, 2016
- Posts
- 825
- Reaction score
- 164
Go ahead. Put anything other than Chevron with Techron in and see how your turbos glow... then sieze up.
This is the only safe product to use. Recommended interval is every 1k miles so that performance is not degraded. This has many years of safe use on the ecoboost and what its owners have to use.
The new 3.5L Ecoboost (both high output version in the Raptor and standard version in the F-150) have both port and direct fuel injection, which is supposed to help keep the injectors cleaner than direct injection alone.
FWIW, I owned a 2012 Ecoboost for 5 years and almost 50,000 miles and didn't have any challenges with the valves (or any portion of the engine for that matter). I also used Gumout Regane (contains PEA) religiously every 3,000 miles and never drilled a hole in anything. Truck had bald tires, dead battery, leaking rear diff, a broken sunroof track and leaf springs that would shift and clank around with every turn (2 different dealers tried fixing with zero results) when I traded it in for my Gen2, but had I zero problems with the engine while I owned it.
