Is this the right one?
E 20" - Spot
Family:
E-Series
Optics: Hybrid - Spot
LED Color:
Finish Color:
Length: 20"
Mount Type: Surface
Shipping Dimensions: 7 × 24 × 7 in
Shipping Weight: 6.15 lb
Sold As: Single
SKU: 120212
Price: $699.99
Quantity *Add to cart
Features:
Patented Hybrid Optics
10° Spot Pattern
50,000+ Hr LED Lifespan
Instant On / Off - No Warm Up
RoHS Compliant
Over / Under Voltage Protection
Extruded Aluminum Housing
Durable Polycarbonate Lens
Integrated Thermal Managament
GORE® Pressure Equalizing Vent
Designed, Engineered, &
Assembled in the USA
Specifications:
Watts: 110
Amp Draw: 7.97
LED's: 40
Raw Lumens: 9200
Lux @ 10m: 3530
Beam Distance: 1188 m
Peak Beam Intensity: 353000 cd
Description:
The Original LED Light Bar - The Rigid Industries E-Series was the first projected LED light bar. Since its introduction in 2006, the E-Series light bar has set the standard in the industry through continuing advances in technology and superior engineering. Available in a wide range of lengths and configurations, our flagship is the light bar of choice for everything from light truck / car applications and vehicle race teams to farming equipment and police / fire rescue vehicles. The E-Series light bar is designed to project light at extreme distances while consuming very little power. It features an extruded aluminum housing and polycarbonate lens that is sealed against the elements to provide years of trouble-free operation.
Hybrid Optics - Our patented Hybrid optics system is the most powerful, most efficient LED optics system on the market. Utilizing a combination of lens and reflector, the Hybrid optics system captures the maximum amount of light emitted from the LED and projects it exactly where you want it.
10º Spot Pattern - The Spot version of our Hybrid optics system projects light over great distances in a concentrated beam. It's the most powerful spot-style LED light in the industry. This light is perfect for high speeds or any situation where you need extreme distance. The Spot offers a wider beam with less waste than the competition. While maintaing higher center intensity than any other system available.
Quality Construction - Our circuitry is designed in-house to be more powerful, be more efficient, and generate less heat. Our durable aluminum housings feature custom, over-sized heat sinks which keep the temperature down and allow our LED's to run cooler and brighter. All Rigid Industries LED lights receive a high quality powder coat finish, a custom-molded rubber seal, and an unbreakable, scratch resistant lens. Rigid Industries LED lights are engineered to withstand whatever you, the road, or nature can throw at them.
Contact your local dealer / distributor for more information about this and other high quality LED lighting products and accessories from Rigid Industries LED Lighting.
Sent from my iPad using
Tapatalk
