front shocks using valve shrader
munther76
hello can i use a valve shrader not that rubber that need the needle to fill the Nitrogen ? also is there enough place between the shocks and lower control arm to not hit the shrader when i install the shock ? sorry for my bad english and thanks in advance .
ExpeditionFatherhood
Danville ,CA
No, you have to use the nitrogen fill needle. You can replace them with shredder valves though, there should be a write up of that somewhere in here!
cups
Fair Oaks, CA U.S.S.A.
I really thought someone will respond with better info than I have. But here goes.
You should be able to use schrader valves on the fronts. This is a question I've asked repeatedly. Only answers received were "yes I've done it to mine". But have not been able to get any clarification. The problem is most people think there is no room for the valve stem when the shock is in the truck. I have not seen an installation of schraders on the front shocks yet. It is on my list of things to try though.
M
munther76
finally i did it
http://store2.up-00.com/2015-11/1447963861493.jpg
---------- Post added at 03:39 PM ---------- Previous post was at 03:38 PM ----------
there is enough gap between the shader valve and the lower control arm
M
munther76
Can't see it well, is there enough space to check or recharge without removing?
yes there is enough space to recharge and check but you have use special fill valve you can find it in ebay ( item no 230985327872 ) good luck
Members online
95,404
58,973
Kwazyace
