Front running lights gone out!
bruceboyer
NorCal
I installed the SVT back lite mod to the center pin of the front amber running light (1 inverter per side). After 1 week, all the front running lights (LEDs, amber bulbs and SVT back lites) have stoped working. Checked fuses - all ok. Anyone know what's going on please?? I saw something about a beige wire to the running lights on F150's getting over loaded and burning up. Not sure if this is real and if it applies to our Raptors. Wouldn't the fuse blow if that was the case?
Thanks for any help, guys.
BIRDMAN
Birdministrator
Boston
i would check and double check ALL fuses and relays, then grab your multi meter and find where the voltage drops
bfr
Mountain West
In trying to learn what the "SVT back light mod" was I found this...
This guy had the same problem I think.
Sounds like he got the dealership to fix his screw up and then rewired it to an AUX switch.
IRONMAN
Well-Known Member
MICHIGAN
Have you disconnected it and returned to stock to see what happens? If not do that and see what happens, maybe something in the system is shorting, need to check your ground, cut wires, but start there remove all and start fresh. See if it works with out it 1st.
bruceboyer
bruceboyer
NorCal
Found the problem with my trusted multi-meter! It was the fuse - duh!! Even though it looked good it had blown. replacement solved the problem. Now I goota find out what blew it and why!! Thanks for all the help and suggestions. I'm suspious of the EL tape inverter.
bfr
Mountain West
I don't know what the EL tape inverter is...but I think the guy said something about that and that he wired it direct to AUX1 switch ??
