front radar
greatone99
ma
I keep getting pre collision not alvalible ,in the center dash , everything is greyed out as well in relation to that, adaptive cruise Ect , took the grill off removed the sensor ,cleaned , made sure the plug is in good ,still same error ,bad radar sensor ????
G
greatone99
ma
I ordered the part , I don't have the time to drop off truck at dealer ,paid 400 for it . hope it does not need to be be programed
Sherman Tank
Mayfield Heights, OH
I am at a dealership collision center and I know the vehicles we service have to be aimed if there is any change n the camera. The camera in the front and the camera in the windshield have to be within a certain degree of each other to work properly. My truck was 1 week old and somebody backed into the left front bumper corner just pushing it back a little bit and it was enough to put it out of aim.
FordTechOne
Detroit
That’s an expensive guess. The Cruise Control Module (CCM) needs to be programmed and a special calibration/alignment procedure needs to be performed in order for it to function. The Image Processing Module A (IPM-A) is also part of the adaptive cruise/pre-collision system; it’s integrated into the interior rear view mirror.
G
greatone99
ma
would the fact I moved my front bumper up about 1/2 -3/4 of an inch throw it off ? meaning did I throw it out of spec
FordTechOne
Detroit
Yes. The CCM needs to be accurately aligned both in the horizontal and vertical directions. The vertical alignment is performed with a combination square level by turning the E Torx adjustment screws. The horizontal alignment is performed with the Ford IDS scan tool.
G
greatone99
ma
so if i attempt to move the bumper back to where i think it goes , will it Possibly start working again
FordTechOne
Detroit
The CCM requires the alignment procedure even if it’s just removed and reinstalled, so the chance of it working properly is not great. Even if you can get the warnings to clear, the system still may not operate properly.
