Front lights
OffroadAlliance.com
Boston, MA
The 10" Baja Designs behind the front bumper, the 30" Baja Designs and pretty much every fog light kit out there will not interfere with the front camera at all. If you're looking for a light bar that mounts to the top of the bumper, a physically smaller light bar like the 40" Baja Designs Onx6 will be visible, but only slightly. A larger bar, such as the Rigid RDS series will be a bit more noticeable. If you are planning on running some kind front bumper light bar mount like the N-Fab, that typically further reduces the cameras visibility depending upon what light bar or light setup you're running.
Give us a call! Plenty of options.
Ph: 888-466-8991
M
Mcd2148
New Jersey
The front camera is used for the adaptive cruis control I did not want to lose that feature. I’m not looking for a behind the grill light. I like the light barv
ReefBlue
Delco . . .
The grill camera isn't used for cruise control. There is a sensor in the bumper.
4x4TruckLEDs.com
anyone know of a front light bar/setup that doesn’t interfere with the front camera?
You have a few options.
1) You can install the Baja Designs 10" OnX6 Kit in the lower grille. Obviously this clears the camera as it's in the lower grille: http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-onx6-lower-grille-led-kit/
2) You can go with the Baja Designs 30" S8 upper grille kit. This mounts behind the upper grille, above the Ford. Since it's behind the grille, nothing gets blocked. And believe it or not this bar puts out some serious light: http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-30-s8-grille-led-light-bar-kit/
Those 2 kits are bolt on. A 3rd option is to mount an OnX6 bar to your bumper. You'd just have to drill into the bumper for the bars brackets but that's not too bad. A 40" OnX6 Arc bar (curved) will do the trick: http://www.4x4truckleds.com/led-light-bars/baja-designs/onx6/arc-series/
It'll look like what this customer of ours did (he's also running our SPP Triple Fog Light Kit available here: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights/)
Take a look at the truck at the top of this ad, he put a 40" Baja Bar on his bumper
Sethrad
Brentwood, TN
Haven’t pulled the trigger yet, but I’m seriously considering an ADD Venom front/rear bumper setup...with a 30” light bar installed in the bumper. Was considering the ADD Stealth R, but was too that it was going to interfere with the camera. Like you, I didn’t want that. It’s a VERY cool setup...and you can keep the ACC as well.
Glefevre87
Ph: 888-466-8991
Seriously considering the 30” upper grill light.
