I hooked up my fully loaded 18ft trailer and it caused my truck to squat quite a bit. As soon as that happened, I got the alert in the picture below. My front camera works fine, but I have no cruise control (non-adaptive nor adaptive). Pretty sure the ride height change caused a sensor to go off.
I used Forscan to find the code. In short, I am getting two codes:
So I tried clearing the DTC codes. I even tried doing a module reset on the IPMA. None of those things has worked. Any suggestions? I would prefer to solve this myself, then to take my truck into Ford. @FordTechOne @zombiekiller
My truck is a 2020, both my front and rear cameras had to be replaced under warranty due to the camera recall last year. I assume the ride height is what has thrown the code and not the camera recall.
