JaxBeachRaptor17
Unfortunately not. Bought it as a trade in from a Toyota dealer in Atlanta, ga. I just had it at the dealership due to the sunroof being stuck open, oil plug leaking post VCT repair, and passenger axle seal leaking. They only charged me for the sunroof but that was still $587.00. They replaced both rails and shield. I mentioned the camera not working and the 2020 recall and service advisor said they couldn't cover. I bought the camera for 67.00 thru another local ford dealer and thought I could do myself. Stuck my foot in it royally as before camera was poor but now I can't even get it up on display.
Did you buy the truck brand new? Ford is usually pretty good about helping out with post warranty repairs if you're a loyal customer.
As far as the camera, it uses a weatherpack seal, which is the industry standard. I'm surprised to see the amount of corrosion on yours for a Florida vehicle; that is pretty bad. How does the harness side of the camera connector look? With the component (camera) side being that corroded, the harness side is probably no better. You may need to have a new pigtail soldered on to the harness to restore camera function. Whenever the camera is replaced, the 360 alignment procedure needs to be performed, which requires special mats and the Ford scan tool (IDS). That is why your 360 camera function is not operating properly.
