Taube2013
I have 52000 miles on my 2013 Raptor, looks like it is time for service/rebuild on my shocks. Is there anyone in Michigan that can do this ? Or is the you remove them and mail them to Fox the only way to get this done ? Thanks Tom
Removal question on front fox shocks do you need to disconnect sway bar or control arm to get shock out? Or can you just jack up and you will have the room to remove and tips would be great thank you!
I started to notice a pretty rough ride at almost 60K. Picked up some rears with about 20K on them from a forum member and it's night and day. Haven't found a good deal on fronts yet but I can tell they're really shot because it's rough when I hit a bump then smooth as the back goes over. Also the front is pretty bouncy over a series of bumps.What are the symptoms indicating it's time for a rebuild? I'm closing in on 50,000 miles.
Thank you 2014 rubyred I did get them removed and decided to send into Fox for a rebuild. Thank you for all the tips it did help out!
