Fox bump shocks??
4XXFORE_SOCAL
Southern California
That sounds like way too much...Bumps run a 1:1 motion ratio vs wheel travel shouldn't need that much N2...My last bumps (Light Racing Jounce Bumps) were 2.375" dia and 3" travel and I had them around 45 psi.
I'll have the boys at RPG take another look... thanks for the recommendation.
Viper01
Viper01
FL
SVC told me 50 psi is the magic number for the fox bumps. Anything more than that will cause the back end to buck.
signalbobby
what bump stop mounting kits are ya'll using for these? Im looking at SVC's. I like Icon's design but not going with Icon's.
waveslayer
CA
I installed the RPG kit on my truck. So far I really like it. I haven't used the Icon, but the RPG fox kit worked well 2 days ago. I was impressed with how smooth the rear end was. Now I'm looking for a bump stop kit for the front if there is even one
My wife thinks I only have 3 guns
Booth9999
Idyllwild
Front bump kit, that’s what we need. I think crazy house did some.
zombiekiller
OG BooBooRunner
New Orleans
I had the RPG bump frame. I switched to the SVC a while ago because the SVC frame has 3 adjustment positions.
I'm REALLY glad I did. If I had stuck with a fixed frame, my bumps would be WAY too low and I'd be hitting them about 3/4 into my bump travel. with them in the highest position, they are in the perfect spot and function exactly how I want them.
I'm running 4.0s in the rear, so I have a TON of shock and only hit my bumps in the biggest of terrain. IIRC my king 2.5 bumps are charged to 40 or 50 psi.
zombiekiller
OG BooBooRunner
New Orleans
when you make your choice, consider that as raptor owners, we're always tinkering, upgrading, etc. The adjustability of the SVC frame gives you some flexibility so you arent rebuying bumps if/when you modify your rear suspension again.
