ForScan fail...I failed at ForScan
CoronaRaptor
CANADA
With friends like you guys, I don’t need enemies…your advice was as worthless as **** on a nun.
I figured it out this evening.
You can’t turn on the turn signals as running lights I found out. It completely eliminates front turn signals.
You’re welcome.
You're welcome, but who the hello would want signal lights on all the time anyway? The Raptor already has extra lights as markers and most people add fogs on the front with different lenses for affect. You would of got more respect if you had of posted a picture of your Prius.
Antho
You’re welcome.
It’s absolutely possible. I’ve had it done on my 17 and 19 but thanks.
The issue is people post for the first time and their post contains absolutely no info. I’m not going to waste my time trying to dig around to assume or figure out what changes you made. revert the BCM back to the factory asbuilt data and start over would be the easiest route. Assuming you backed up your factory asbuilt data…
DINOZR
Southeast
This forum can be really helpful, especially for things like Forscan. There is an expectation that if we are to help, the OP should provide enough info for us to help. With Forscan this would mean "I made these changes [*** XX XXXX] to this address [***] and got the result that my turns are on all the time." Forscan is detail oriented stuff. We can't help without the nitty gritty details. But if you do the work of providing all those details, people will dive into the spreadsheet and provide help you wouldn't believe.
tdford6
Colorado
Pretty sure I was able to make the turn signals act as "DRL" alone. I did not want that, I was trying for just orange halo's. I ended up with parking as "DRL" but only ran that for a few months. I went back to stock with some fogs on.
