Ford Truck Brakes for Optimal Performance
carid
Cranbury, NJ
Just the other day at a local truck rally, I had a chat with an owner who felt that as long as his truck could stop, his brakes were fine. I pointed out that effective stopping is more than just halting your vehicle—it's about how reliably and safely you can do so, especially with a full load or in demanding conditions. This chat really highlighted a common oversight I've noticed: many truck owners underestimate the need for regular brake system upkeep.
View the full list of replacement brake components for your Ford truck on this page:
Brakes are crucial—they literally save lives by preventing accidents. Consistently maintaining your brake system is essential not only for your safety but also for enhancing your vehicle’s overall performance. Letting maintenance slide can degrade your braking power and lead to dangerous situations.
Brake Pads
At CARiD.com, we offer an extensive assortment of brake pads designed to meet various driving demands and conditions. Choosing the right brake pads means considering the environments you typically drive in—whether it’s urban settings, heavy-duty towing, or off-road adventures. For those often driving on mountain roads and dealing with brake fade during long descents, we highly recommend our high-performance metallic pads, which are built to withstand high temperatures.
There are mainly three types of brake pads: ceramic, metallic, and organic.
  • Ceramic pads are known for their quiet operation and less dust but are typically more expensive.
  • Metallic pads are great for heat dissipation and durability, making them ideal for heavy-duty applications.
  • Organic pads are made from a mixture of fibers and fillers, which are gentler on rotors but wear out faster and are less effective in extreme conditions.
Popular brake pads for Ford trucks:
The full list of brake pads for Ford trucks here:
Brake Rotors
We provide a diverse range of rotors at CARiD.com to suit various preferences and needs. Whether you need drilled rotors for better heat dissipation, slotted rotors for extra grip, or ventilated types for heavy-duty applications, we've got you covered. The right rotors can make a significant difference in how your truck responds to braking, particularly in stressful situations.
Some of the most popular Brake Rotors for Ford trucks are:
View the full list of Brake rotors for Ford trucks here:
Complete Brake Kits
When upgrading your brake system, considering a complete brake kit can be your best bet. These kits are beneficial over piecemeal purchases since they guarantee that all included components are compatible and typically come with everything needed for a full upgrade—rotors, pads, calipers, and sometimes even new brake lines.
Popular brake kits for Ford trucks:
The full list of replacement brake kits for Ford trucks:
Need some guidence and how-to instructions? - Read our tech articles!
Regular checks and upgrades are essential to ensure that your braking system remains in top condition, providing you with the confidence and control you need, no matter the driving conditions. Don’t wait for signs of failure - proactive maintenance is key.
Leave a comment if you have any questions about the brakes - we'll be glad to help!
carid
carid
Cranbury, NJ
Hello truck lovers! We’re rolling out some hot deals on PowerStop brake kits at CARiD.com! Gear up for an upgrade and snag up to $85 off on our high-performance brake kits until August 15, 2024. Whether for daily driving or heavy-duty towing, PowerStop delivers the reliability and durability you need.
Thinking about a brake upgrade? There’s no better time than now! PowerStop kits come with everything you need for a smoother, safer ride. Plus, with our prices already slashed, you get top quality without the high cost. Shop with us and save—no fuss, just great value.
Catch this awesome deal before it's gone! Enhance your braking performance with PowerStop and enjoy some serious savings at CARiD.com. Upgrade today, save big, and feel the difference in your ride. Offer valid through August 15, so act fast! ️
PowerStop® - 1-Click Z23 Evolution Sport Drilled and Slotted Brake Kit with Calipers
Overwhelmingly positive reviews with an average rating of 4.7 out of 5 ⭐⭐⭐⭐⭐
You can read user reviews here:
Note: Check out "Product Options" to choose your specific model.
Key features:
  • Precision machined using a Tru-Cast™ technology
  • Rotor run out is within 0.0015 and DTV tolerance specification is within 0.005
  • All Evolution rotors are mill balanced
  • Rounded slots keep a clear contact patch between the pad and the rotor by sweeping away water, gas and dust
  • Beveled and precision drill holes help keep rotors temperatures down during extreme braking performance
  • Pads, rotors and clips are designed in the precise size and shape of factory OEM parts for proper fit and operation
  • Carbon Fiber infused Evolution ceramic formula for superior braking power
  • The pad surfaces are thermal scorched for a fast break-in
  • Chamfered and slotted like the OE pad to ensure noise-free braking
  • Powder coated backing plate extends life by resisting rust and corrosion
  • Premium rubberized shims provide virtually noise-free-braking
  • Premium stainless steel hardware kit included for easy installation
  • Ceramic based lubricant specially formulated for Z23 Evolution Sport pads
  • Ceramic pad compounds wear slower and last longer than OEM equipment
  • Reduced heat buildup eliminates brake fading that occurs when brake fluid reaches boiling temperature
  • Includes rotors that are cross-drilled and slotted for more effective cooling under heavy use
  • Advanced brake pad compounds produce less dust than OEM factory brake pads
  • Brake pads and rotors offer eliminate squealing under the most extreme cold or hot temperatures
  • Bolt-On Ready: no modifications needed to your Vehicle
  • 3-year/36,000 mile manufacturer limited warranty on the rotors and pads purchased and installed together
PowerStop® - 1-Click Extreme Z36 Truck and Tow Drilled and Slotted Brake Kit with Calipers
Rotor benefits:
  • Drilled holes and Slots create an escape route for debris, dust, gases, and water
  • Slots clean and de-glaze pad surface for optimum pad coefficient of friction
  • Slots help to increase pad bite and improve air circulation
  • Drilled holes and Slots reduce stopping distances in wet weather
  • Drilled rotors improve the appearance of your wheels and provide reduced rotor weight
You can browse the full catalog of PowerStop brake parts at the link below:
Check out other active sales events and promotions here:
