Addictive Desert Designs
Happy to hear it worked out for you. Thanks for coming down and working it out with us.
The 450x compressor is a completely sealed unit. You can splash it down all day and not have to worry... that assumes you've remote mounted your air intake filter. You'll need to get that intake up away from water or you'll suck it in, and hopefully blow a fuse before blowing the compressor itself.i like this idea....but what about it being exposed to the elements? i just soaked my truck in mud this past weekend and im wondering how it will effect this compressor?
Speaking of remote mounting the intake filter, here's my solution (hopefully sparks an idea or two for the ADD solution)
http://www.svtoffroad.com/showthrea...board-Air-System&p=24409&viewfull=1#post24409
Hi 'Rat. I'm no expert, but I believe the answer is 'yes it will run it, but not well'. To run a tool like that you want a constant source of air. A compressor without some sort of buffer tank will give you a pulsating source of air that may or may not be enough to power the tool strongly, to break the nut and/or keep it spinning. And I definitely wouldn't trust it to tighten alone (say a wheel lug nut or some such).I'm new to portable compressors. Will this thing run an impact wrench?
