Ford Raptor 2020 Belgium
FordTechOne
Detroit
Update: I found out that under the hood right next to the hinge for opening the hood there is a connector for the lights. And in this connector the blue wire is out, I think this is the problem. But I do not know if this was on purpose. In Belgium it's not allowed to have drl in another color then white, therefore they placed some additional white Led strips that function as DRL.
Tommorow I will reconnect the blue wire, hopefully the car doesn't explode.
Hello and welcome.
It sounds like you may have found the issue. The connector you found is C133, should be an 8 pin. Circuit CLS05 passes through this connector and provides power to the grille marker lamps; it's blue with a gray tracer. It sounds like it may have been intentionally disabled during the import process; repairing that circuit should restore your grille marker lamp functionality.
CoronaRaptor
CANADA
If it explodes, can you please post a video, I would love to see that.:eek:
Stef700
Stef700
Bree
Hello and welcome.
Yes it's a 8 pin connector and the blue with grey tracer is pulled out, but I can't messier any current on it. Do you know where this wire comes from? To the grill lights it's all wired, it is the wire coming from the passenger side that is disconnected at this connector, but like I said no current on it.
sixshooter_45
Arnold
If it's disconnected, then there will not be a load you could apply to it therefore you won't be able to measure current.
Stef700
Stef700
Bree
That I understand, it was at the positive side where there was no load, but I was because I had my lights on automatic. I changed it to DRL only and u got current. I reattached the cable to the original factory connector and the 3 grill lights work. the 2 side marker lights are not doing anything, so that will be my next quest.
sixshooter_45
Arnold
Yeah, probably another wire pulled out of a connector.
Alar
Estonia
Well when I got my Raptor in Estonia in 2014, they just unplugged the hood marker lights to register the car. I just plugged them back in. Police just doesn't care here :D
