Ford Performance Tune for Gen 3s
WatFam
HTX
I installed this today myself. It was really easy. Really like what it does to the 10-speed. Ford might ought to market it as mainly a transmission tune that also gives you a little more power under the curve. The smoothness is super noticeable.
$650 isn't so bad, and I like the truck even more now.
GordoJay
Colorado
I'm a previous (very disappointed) '21 RAM Rebel owner and a current (mostly happy) ’23 Raptor owner. Even though I like the Ford better, the RHO is faster 0-60. Seems to be about 5.1-5.2 seconds, while the Raptor is between 5.6 and 5.9 seconds depending on who you believe.
I’d still buy the Raptor, but the RHO is faster. Ford Performance’s new tune is, well... sad.
Measuring an off-road truck designed for high speed desert running by the 0-60 time is like measuring the value of a cow by how fast it is instead of by how much milk it produces....
shigman
Cypress, TX
Would you mind giving an update in 3 months or so in case the “learning tables” effect things after the tune? It is encouraging to hear, but I feel much better transmission behavior after using Forscan, but then the odd behaviors always return. Thanks for your feedback on this tune at this point!!
WatFam
HTX
Yep - definitely will.
Boston, MA
You can use the ProCal to erase the learning tables.
FoxNotch
Michigan
That tiny torque and HP gain will not do anything to compete with the RHO. I had a MPT on my 17 with an E30 and the best run I had was a 12.9… 93 tune I ran 13.1… what the RHO supposedly runs. TFL will likely do their runs against a stock and tuned Raptor as they usually do.
TFL will do some comparing with times then those idiots will do a towing test up the “Ike”.
