Ford Performance Diff Cover
Jakenbake
I’m torn between this one and the mag hytec
I don’t have any experience with the mag hytec, I’m sure it is a good product, but I went with the ford performance/spicer one for a few reasons.
I did quite a few water crossings/mud holes on a weekend trip and wanted to change my fluid. The spicer one was unavailable so I paid a little more and got the FP one.
The FP one closely resembles the stock one and should not create any turbulence in the fluid, see banks engineering videos on diff covers.
I think foutz makes a skid plate that will fit the FP differential cover and I likely will get one of those.
Side note, I noticed a small leak after my last trip and I checked the bolts, almost half were so loose that I could hand tighten them. I put the 3/8 torque wrench on them and took them to 20ft*lbs. When I originally installed it, I used a 1/2” ratchet and got them tight, I did not have the ability to take them to 14 ft*lbs as prescribed in the instructions. I’ll keep an eye on them, but if they loosen again I may use loctite.
IamCanadian
ON
I forgot Ford made the subj item. I know what I'm asking for Christmas..
RaptorJoe92
Colorado
Bumping this old topic because I can't find a clear answer anywhere...
When using the Ford Performance/Spicer diff cover are you guys filling to the top or bottom fill plug?
Bubbasuwannee
Angier, NC
Thanks. I had read that but I wasn't sure if Raptor suspension changed the angle compared to a regular F-150. Any chance you know how many quarts it takes?
It's about a quote more than factory. 3.5 quarts I believe total. Don't the bolts or gasket that comes with it. Use a lube locker gasket and the factory bolts or ARP bolts. Put out a video from the last time I installed one.
RaptorJoe92
Colorado
Spicer cover and lube locker gasket are in the garage waiting for install this weekend. Planned on reusing the factory bolts. I'll check out your video, thanks for the help!
Bubbasuwannee
Angier, NC
Nice! Yea another thing is thread locker on the bolts and torque in a cross pattern to half torque then torque again to full torque.
