Ford ABS/Brake gremlin
Johnny@Apollo-Optics
TX
Any ford techs heard of a truck consistantly pushing ABS code c1013? The dealers just keep replacing the hydrobooster module at the request of ford engineering support but thats clearly not the problem. Brakes have been bled 100 times, and all ABS wheel speed sensors have been swapped. The dealers had my truck since May 08 and at this point we dont know what else to do since thats what the workshop manual says to do for these codes and the engineers in Ford are also telling them keep changing hydroboosters
Symptoms: driving, sometimes when braking the abs and parking brake light comes on. Lose hill start assist, adv track, etc. happens regardless of drice mode. Turn the truck off and back on and it all goes away with no issues.
It doesnt mechanically effect anything until the lights come on which leads me to believe theres an electrical vs mechanical issue.
Trucks not tuned.
@FordTechOne
FordTechOne
Detroit
Since they already replaced the Electric Brake Booster (EBB) that can obviously be ruled out. Are the brakes the factory 2 piston front/1 piston rear?
TX
Yes they are. The whole brake system and electronic system of the truck are completely stock.
TX
Do you have the conditional code by chance? Example C1013:09?
its 7A thats the sub-code.
The dealer called me theyre doing another hydro booster. Essentially they pin a slight drop in pressure that causes all these issues so itll be swap #4 per the engineers in detroit.
FordTechOne
Detroit
Ok, 7A is Brake System Pressure: Fluid Leak or Seal Failure. I’d suspect either they’re not getting all the air out of the system (requires a pressure bleeder) or there is a faulty brake system component, such as a caliper with a piston that is over retracting. The engineers can only make recommendations based on what the dealer tells them, but I doubt they’ve received 3 faulty EBBs in a row, especially if the current DTC is the same as the original.
TX
Should I recommend changing calipers to them? Not sure how to hint them at this since theyll only do what the codes tell them
