Awesome deal at Costco - jump on it now...
Aluminum 3 Ton jack...it has a dual pump - unlike some of the other floor jack models which take quite some time to lift loads, this one comes with a dual piston pump that facilitates the fast rising action.
$104.98 shipped to your door from...
Costco!
https://www.costco.com/.product.100222458.html?EMID=B2C_2017_1208_TireSolo
The Arcan 3.0 Ton Professional Grade Aluminum and Steel service jack combines the strength of steel with the light weight benefits of Aluminum. This jack only weighs 58.3 pounds so transporting from one place to another is very easy. Designed for use at home or a repair shop, this jack delivers the lifting capacity you need to get the job done. It features a low entry design for low ground clearance needs. With a capacity of 3.0 tons, this is the perfect jack for both cars and trucks. Whether you're a professional mechanic or a do-it-yourselfer, the Arcan 3.0 Ton jack has what it takes to make any lifting job easier.
Features:
Aluminum and Steel Construction
Safety valve prevents overloading
Dual pump pistons for rapid lifting to the load
Dual return springs
Rubber saddle pad protects underside of vehicle
Side handles for easy carrying
3.0 Ton lifting capacity
Dimensions:
Min. Lift Height: 4"
Max. Lift Height: 18.6"
Weight: 58.3 lbs.
Caster Wheel Size: 1.8" x .9"
Front Wheel Size: 2.6" x 1.6"
Saddle Diameter: 4.6"
Handle Length: 45"
Overall Dimensions: 24" x 11.9" x 6"
Compare it to any Harbor Freight jack - you'll be pleased
https://bestfloorjackguide.com/3-ton-aluminum-floor-jack-reviews/
