baja-chris
23 R. Swapped in the new Fox race series 3.2 Live Valve, added Fox air bumps on all for corners and Foutz UCA. I had the front air bumps sleeved so they only have an inch of play, (approx last couple inches of wheel travel since they contact about half way up the lower a-arm). All I can say is WOW. It works super good in a variety of desert terrain, from fast trails, to washouts, whoops, and tight rocky UTV trails. Big improvement over stock. I hit stuff at 40-50 mph that previously bottomed and kicked and it just sucked it up. Had it over 100 on the graded road and rock solid. The sandy UTV trails where badly washboarded and it was still rough there but my main goal was to improve big hits where a washout or hole sneaks up on you at speed. Much better in that regard. Running 32psi cold. Stock 37" KO2's, stock rims with real beadlock rings. Next outing is NORRA. Switching to KM3 when the all terrains wear out.
