H2O Guard & Gloss on Wheels
Well, its gonna rain tomorrow, but I went ahead and washed the Raptor so I could demo the H2O Guard & Gloss (HGG) on the wheels.
After I finished the wash, I left the wheels wet. I took a Single Soft Towel, got it wet, and wrung it out, not too dry, but not dripping.
I folded the towel in quarters, then put 5-6 sprays of HGG on the towel, and wiped the surfaces of the wheel, going over it 2-3 times, making sure I did not miss any areas.
I did not spray the product directly on the wheel, to avoid having gloops end up in places that would be hard to get wiped.
I used a dry Single Soft Towel and wiped the wheel, leaving a nice, even shine.
On the next wheel, I switched to a clean quarter of the towel, sprayed more product on the towel, wiped the wheel, then dried with the dry towel. Repeated for the remaining two wheels.
The reason I switched to a clean part of the towel for each wheel is that you end up with some dirt on the towel, getting to the inner parts of the wheels, since the towel ends up touching the calipers, rotors, barrel, etc. This prevents scratching the wheel by using a dirty towel. I will also wipe the outer face of the wheel first, and then do in inner areas last.
In this photo, you can see what the towel picked up, and I cleaned the wheel really good with the Short Wheel Brush, the Trim & Lug Nut Brush, and the Wheel Woolie.
Not the best pic, as the light was not great when I finished, but the HGG does give some good shine, and will last about a month on the wheels.
The good thing is, it took less than five minutes to do all four wheels. I found that this was faster than using Quick Sealant, as I would spend way more time than that just getting the wheels dry in order to apply the Quick Sealant.
One more tip, use dedicated towels on your wheels, don't use a towel on your paint that you previously used on your wheels, even if it gets washed. I use the Borderless Gray Towels for HGG on paint, trim and glass, then use the Single Soft Towels for wheels.
