Donmatteo
You don’t know what I know so don’t assume.it happens. Man probably doesn’t know the rear leafs aren’t the best because it’s on a block. Front springs improved the ride as well. Less body roll and less front end dipping when braking. Not to mention my fenders allowed for easy clearance on the 37s
Fine. Fair enough.See here is the thing your getting "your opinion" and "incorrect assumption" mixed up.
No matter how many times you say it in this thread they guy hardly did anything to the suspension. so yes i agree that suspension is PART of what defines a raptor it was hardly enough changed to warrant starting with a base f150.
The fenders also are specifically built off the raptor mounting points and brackets. and again the OP only did the front fenders which constitutes maybe 15% of the whole raptor body, also not enough to warrant starting with a base f150, and so this same theme continues...
So if you want to say it looks cartoonish, or you like the wrap but not the wheels, thats fine as as you put "your american right!". The issue is when you start throwing in incorrect assumptions, like "he replaced everything that makes it a raptor" plain and simple that is completely false and no where near accurate. This is why i said back away from the keyboard. not because of your opinion but for the "incorrect assumption" you were starting to say, and the way this forum operates, the assumptions you were going to attempt to support. so i jokingly made a jab that for your own good just stop cause you were going to get poked at by others
There seems to be a disconnect as well between speaking in general terms and absolute specifics when it fits someones point of view.
Obviously there are 1000's of parts that are different and there is more to the raptor than what I listed, and even more than what you listed so I guess I can point out how you assumed based on your general statements?
You do understand the difference between general and absolute right?
I guess I should have busted out the parts catalog to compare and contract as well as the engineering spec's to make a point that it looks like a cartoonish brodozer with those wheels and be dismissive of the changes?
Be real man. srsly. Next time I'll put a "WARNING: GENERALIZED STATEMENT AHEAD"
