False overheating engine - Not sure what to do
Thanks for reporting this cautionary tale. I’ll be near the pass-thru harnesses again when new lights come in.
Nick Masturzo
Ca
Success!
After re-connecting the battery, I used the Forscan software to clear the engine coolant error code. All is wokring fine!
Thank you!
I did this same thing still no success after 10 plus minutes off the battery...did you re remove those 2 pcm connections when you re did the 10 mins off battery ...freaking rough as hell and throwing the same overheating ⚠️
Nick Masturzo
Ca
Sounds like i need the OBD link mx and Forescan
and just like that... this thread is reanimated...
edit: :)
you probably have DTC stored. Read them, note them try clearing and then battery reset. good luck.
better than a new thread. a cheap scanner will probably do, unless you want to do the forscan thing, and change up a bunch of stuff
kandewinn
Well, in his defense, had he not revived this thread Nex would have hit him up with “Have you tried using the search function? It’s in the top right. There’s at least one obscure thread covering this.” Clearly, he has been well trained.
I knew I should have thrown in a smiley...
Not throwing shade on you @Nick Masturzo, just being facetious.
