Factory sub woofer wiring connection
SilentShooter
Siesta Key, FL
So i picked up a Kicker SubStage SF150C09 (for a great price)and the install directions SUCK. This should be enough to hold me over while I do performance mods then I can come back around and do a full system.
I have everything wired up but I can not figure out where the hell kicker expects me to plug in to the factory subwoofer feed.
The wiring harness has a white connector with two pins that they say should connect to the factor harness. I have no idea where the factory harness connects the subs. I would have thought they connected where the sub is installed but nope and they give zero direction or pictures of where its found or what it looks like.
The connection is by the passenger kick panel where the sub ground connects but is separates from the harness and has a couple feet of extra length so I guess it could even be behind the dash, but I checked on the rear of the MFT and did not see anything with a two pin connection.
