Factory Remote Start
CoronaRaptor
CANADA
Are you using it so precool your truck? I'm guessing as you are from Arizona, seems like a waste of fuel if that's the case. Not judging, to each their own, for sure.
J
Joeeyyy
Arizona
My concern was from a wear perspective, hard start, electrical issues, early component failure that may result from constantly using the remote start function. Also, I do not use it to precool the vehicle. Right now the weather is 40-50 degrees in the morning, so I like to let my truck warm up a few minutes before I drive it to work. Often by the time I get to work, which is approximately 4 miles away from my house, my truck hasn't hit 180 degrees.
CoronaRaptor
CANADA
Gotcha, yeah, probably a good idea to warm it up, so moisture doesn't build up in the exhaust, etc. I don't have remote start on my Gen1, but I do on my JK and use it all the time when it's cold out, to me that's when it's below freezing, it's all perspective, regardless, I haven't noticed anything wearing out, although I did have to change the starter in it this year, but I wouldn't contribute that to remote start as I'm only starting it once, not repetitively.
FordTechOne
Detroit
There’s nothing to worry about in that regard. Since you’re only driving 4 miles, it’s better to let it run for a minute or two to warm up.
digscruze
South Fla
Cant live without it, especially during the summer months. I suppose it’s also better for the engine in the sense that it allows it to properly warm up before you start to drive it.
I don’t see if an issue unless you let it idle for long periods of time. But I believe there’s a 15 min cap as well.
anothervr6kid
West of the Mississippi
I used it all the time. No issues. I usually started the truck a couple minutes before I left the house and drove it very nicely till I got to the freeway. That was enough to warm up the engine.
