Well there is no fog light switch on the Gen2 Raptors...
There are 6 upfitters on the Gen2 Raptors that you can do things with.
If you want to install fogs you can utilize those upfitters and go with our SPP Triple Fog Light Kit
Our SPP Triple Fog Light Kits include everything you need in 1 easy to install kit.
-Stainless Steel Brackets made right here in America. Designed by a Roush dealer to serve a purpose (a high quality adjustable bracket)
-3 Pairs of Lights of your choosing so that you get the best bang for your buck
-A custom-made, Raptor specific all-in-one wiring harness to make things real quick and easy on the installation side
-All the nuts/bolts/instructions you need to get this bolt-on kit installed in no-time.
Plus we're always at your disposal to offer tips/tricks and assistance.
You can settle for other fog kits that have cheap brackets that bend at the mounting locations. OR you can grab this kit with some of the most sturdy, adjustable brackets on the market. We're also letting you choose all 3 pairs of lights, so we're not locking you into a light you're stuck with.
Not sure what lenses to go with? Well let us help you pick, and if you go with the Baja Designs lights you can always change them out later on... WITHOUT removing the lights/brackets. Our kits let you change your lenses quick and easy. You don't have to disconnect any wires, remove any brackets or remove the lights. Can't beat that.
Available here with your choice of Baja Designs or Rigid Industries lights (you can also grab the brackets/wiring harness and use whatever lights you like)
http://www.4x4truckleds.com/specialty-performance-parts/
