Alrite just installed it this way and it works great with after market washers. I wouldn't use the stock washers with the kit, Cause on the 2nd attempt opening it it snap the inside washer lol. Otherwise it seems like a great fix now![]()
By the way if you dont have a stick like prybar used, Then look in your tool box for a long enough extension for a ratchet set. I just zip tied the 10M wrench to that. Just an idea for you guys.
So after tightening the worthless bolt on the tailgate for the 15th time it finally broke. I emailed dz for a replacement bolt at they sent me a whole new setup that is engineered much better. The new setup's tailgate bolt is an expandable retainer that seems to lock in a lot better. The new setup doesn't bind the cable as much either. If you have the old one give them an email.
