Wait. I thought it was just me not doing something correct. So I'm not crazy? Was wondering why the HVAC wasn't in balance with outside like my old 12 F250. That one worked like a champ everytime. seats and vents were always on. Now, raptor sometimes puts on aircon seats when it's in the 50's (cold for us here in So Cal LOL )The dealer did an software update and replaced the temperature sending unit under warranty on my '18 and haven't seen the issue since.
That is exactly why. It will drop immediately to account for sudden temp drops, but increases take time to avoid being affected by the engine. If the temp display says it's 38 degrees outside, people will complain when they slide off a road that is covered in ice because it's really 28 degrees.
The "slow rise" was not an issue until Ford started using it as a determinant in the functioning of the HVAC. Tell you what Ford- screw the outside stuff altogether. If I put it to 80, give me 80 degree air. If I put it on 55, give me 55 degree air. Simple enough.
Temp sensor is messed up
Can someone please explain the complaint?
The outside temperature on the info screen doesn't change as it gets hotter outside?
Only when doing low speeds or stationary?
So if you turn on your car at 7 am and its 75 F, if you don't go over 30 mph or its stationary, it'll keep showing 75 f?
