Extended ignition start issue
patire19
NJ
Not sure how to even explain it but I notice that sometimes when I start my 17 gen 2 it cranks excessively before it actually turns over. It never has an issue actually starting but it just makes me worry. Anyone have this issue?
JefferyGT
Vantucky
Is your fuel pump priming when you open the door? If not, there may be a delay to fire up.
mashtastic
las vegas nv
Are you parked level? Extended start time isn’t bad, the oil starts pumping into the turbos before ignition. It’s recommended after every oil change.
FordTechOne
Detroit
Sometimes mine cranks longer as well, starts within a few seconds though. Just depends on how quickly the PCM can get a reading on the Crankshaft trigger wheel. Nothing to worry about.
patire19
patire19
NJ
fuel pump is priming when i get near the car so its not that. But i feel better after reading FordTechOne's comment regarding it.
