How To Eliminate the Sloppy Fit Between Receiver and Ball Mount
Java
MI
Good write up. Here in Michigan rust mitigates the free-play. Your way is better.
R1jamn
R1jamn
Shimmed Another Ball Mount
I shimmed my 2nd ball mount.
This time I used 316 stainless steel for the shims.
R1jamn
R1jamn
Looks good. What bolting hardware are you using?
Hey Joe.
I'm using 8-32 unc (.375 long) flat head cap screws (grade 5).
I'm not using a nylock or nut on the inside of the 2x2 ball mount.
I just tap the hole and assemble using the flat head screws and blue loctite.
mountainsco
Really slick fix. If you leave it in all the time, I wonder if wrapping it with some stainless wire would do the same thing with a lot less work.
Goofball
I wish I had your time, patience, money, and of course... skills.
