AbnMP13
I know you said your not electrically inclined, however, an EASY test to check a battery drain is to take a DVOM and set it to AMPs and attach one side to your battery ground and one side to your vehicle ground, then disconnect the ground from the battery and monitor the amperage. Anything over .030 amps is a giveaway to a parasitic drain.
Then you simply pull fuses until the amperage comes down, the fuse you pull that lowers the amperage is the circuit with your problem. Then just inspect that circuit.
Where is the connector when you disconnect the ground from the battery?
2014 Terrain SuperCrew
Vortex Mud Guards ~ Husky Floor Liners ~ Rigid Dually Flushmounts ~ Rigid Dually Clear & Amber Pods ~ Recon Smoked Mirror Lights ~ Bakflip FiberMax & BakBox ~ SVC Tune ~ Rigid 20" E2 Series - Combo ~ Mid Perch ~ Underhood & Bedlights ~ Rigid 40" Combo ~ ADD Stealth
