An electric pressure washer with a bit more power, and a higher quality
Foam Cannon makes for much thicker foam that will have more hang time.
When the
Foam Cannon is used as a pre-soak to help loosen up crud prior to the pre-rinse, then the longer the foam clings to the paint, the more time it has to loosen up the crud, allowing more to be rinsed away before you ever touch the paint with your wash media.
When the
Foam Cannon is used as a replacement to the suds bucket, which is how I always wash, then the longer time that the thicker foam clings to the paint, the more protection that is still on the surface when I use the wash media.
To be an effective replacement to the suds bucket, I use the
Foam Cannon to apply shampoo to just a few panels, then use the wash media and rinsing the media in the Rinse Bucket, then move to the next area on the vehicle, foam it up, wash with media, rinse the media, and so forth.
I have found that the extra suds on the paint from using the
Foam Cannon, compared to using a suds bucket, is more effective and safer for the paint, since there is more lubrication on the surface.
Also, the black version of our
Foam Cannon is part of the current
Flash Sale. Use the discount code MARCH15 to get it for only $42.49.
Yes, that's a black Raptor under all that foaminess!
