radelow
So I got my Whipple Supercharger installed last week. Everything has been running perfect. No problems whatsoever. I have put around 200 miles on it since the install with no problems. However yesterday driving home all of a sudden the speedometer started fluttering around and the transmission shifted in and out of neutral even through I was in drive. It also appeared the throttle wasn’t taking my input on the pedal. It was intermittent and would come and go. The big wrench did show up on the display. Eventually I pulled the truck over to pull the codes. At that point it wouldn’t even start. It just clicked. After a few minutes it fired right up and I kept driving home. Happened a bunch more times on the way home (shifting into neutral) but I managed to nurse it home.
Following codes were present:
P0706 - Transmission Range Sensor A Circuit Range/Performance
P0707 - Transmission Range Sensor A Circuit Low
P0365 - Camshaft Position Sensor B Circuit (Bank 1)
P0369 - Camshaft Position Sensor B Circuit Intermittent (Bank 1)
P0390 - Camshaft Position Sensor B Circuit (Bank 2)
P0394 - Camshaft Position Sensor B Circuit Intermittent (Bank 2)
Definitely seems to be some kind of electrical gremlin but not sure where to start looking. Any suggestions? I plan to take back to the install shop if I can't track it down with some simple solutions on my own...
Thanks
Thanks
