Eibach Pro-lift springs installed with pics and comments
Kyle Nezat
Louisiana
Ford dealership said they can’t get the truck to the eibach specs. They said they can however get it to factory specs wich I guess will have to due
Ski4Ever
Denver, CO
Why couldn’t they do Eibach specs? Not enough adjustment, or they’re not allowed to do anything but factory specs?
What are the differences between the 2 specs? Where did you find the Eibach specs?
NEOGARAGE
North Royalton, Ohio
Last I checked Eibach doesn’t have specific specs?
We’ve always had the Raptors put to OEM spec, but obviously make sure camber, caster and toe are all within OEM spec by a few tenths so it doesn’t cause excessive tire wear or steering problems.
Kyle Nezat
Louisiana
It has specs on there website for the raptor with the pro lift kit specs
Ski4Ever
Denver, CO
Where do I find the alignment specs on the Eibach website? I found them the other day, but I can't find them now (and I'm in the middle of replacing my front springs today, so I'll need to get an alignment either later today or tomorrow, so I need to know what to tell the shop).
Here's the link to the pro lift kit if that helps: https://eibach.com/us/2190/E30-35-038-01-20-FORD-F-150-pro-lift-kit
Thanks!
[EDIT]Update...I found it! https://eibach.com/us/files/pdf/ford-150-raptor-2017-pro-lift-kit.pdf[/EDIT]
element217
Los Angeles
So I know the general consensus of Eibach versus Geiser springs are Eibachs are more for street and light off road use where as Geisers are more for off road and jumping. Question I have is - is that mainly because the Eibachs are "newer" and have not necessarily gone through the paces like the Geisers or is it something more that that?
