Eibach Pro-lift springs installed with pics and comments
RonPorter
El Segundo
225.00. Stage3motorsports. Free shipping and no tax!
Edit: FRF does not recommend the use of this noted company.
RonPorter
El Segundo
Hi all. I have done my due diligence and have searched FRF for the Eibach alignment specs to no avail. I called Eibach and they are closed. I have an early am appointment tomorrow. Can someone please provide me with the specs? 2019
Thank you in advance...
Simplejack
dallas tx
for 2018 not sure if same for 2019 or not.
TECHNICAL INFORMATION
FRONT:
OE rate: 93 N/mm (533 lbs/in)
PRO-LIFT-KIT rate: 102 N/mm (583 lbs/in)
Bump-stop: OE
Damper: OE
Tubing: N/A
OE hub center to fender: 608 mm
PRO-LIFT-KIT hub center to fender: 672 mm
OE Camber = -0.9 -0.7deg (+/-0.1 deg)
PRO-LIFT-KIT Camber = -0.4 deg
OE Toe = 0 - 0.2 deg (+/-0.10 deg)
PRO-LIFT-KIT Toe = 0.1 deg
Leftsidej
Missouri
Venerous
California
Good eyes GLOCK26...Yes, that is Ocotillo Wells
Ocotillo! Awesome! When I was stationed down in SD, we'd head out there (Ocotillo/Plaster City) all the time with the bikes and sand rails. Thanks for jump-starting some good memories!
Big Blue
Big Blue
Administrator
Staff member
Admin
USA
such poor customer service from them and they're not a supporting vendor
Agreed. I highly recommend that members take advantage of the Forum Vendors here. Their service is awesome and their pricing is as good if not better than any internet vendor. FRF can assist with forum vendor issues, if you buy from non forum vendors it's your issue alone.
