Eibach Pro-lift springs installed with pics and comments
Wfo
Syracuse
I installed the new eibachs on my friends avalanche 17 scab today. I have an 18 screw with used Geisers. I’m really surprised how tall the eibachs are even though they will settle a little. 22CE8CB8-602F-4C7B-866D-F279C4A9355C.jpegB2DB5ED7-2A3D-4739-8ECB-305FE17BF4B0.jpeg
GR8Ride
Upstate New York
f150jack great pic as that will be my truck in a few weeks when it arrives and the Eibachs are installed. Are you still running the 17’s with the 35’s?
Thanks!
Simplejack
dallas tx
yes shop aligned mine right after installing. big blue posted specs early in this thread maybe 2nd page but here is a copy of it.
TECHNICAL INFORMATION
FRONT:
OE rate: 93 N/mm (533 lbs/in)
PRO-LIFT-KIT rate: 102 N/mm (583 lbs/in)
Bump-stop: OE
Damper: OE
Tubing: N/A
OE hub center to fender: 608 mm
PRO-LIFT-KIT hub center to fender: 672 mm
OE Camber = -0.9 -0.7deg (+/-0.1 deg)
PRO-LIFT-KIT Camber = -0.4 deg
OE Toe = 0 - 0.2 deg (+/-0.10 deg)
PRO-LIFT-KIT Toe = 0.1 deg
vazo
I contacted eibach and asked them about springs for my 2018 and if the springs will settle over time.
He said no they won't. In fact he told me that the springs will lift the front 2.5" and that the front will be higher than the rear possibly by an inch.
I want a leveled truck with maybe the front being a bit lower not higher.
Can anyone who has installed these springs confirm this?
Do you have before and after measurements of the front and the rear and whether or not the front has settled over time?
Sent from my SM-G960W using Tapatalk
SoxFan
Virginia
2017 SCREW, 20K miles. Before front 39.5" after 41.5", still holding at 41.5" (3 weeks after install). Truck sits level, perfectly flat!!
FrodoTBaggins88
US - Utah
My Eibachs did not lift 2.5" I can tell you that much. Maybe 1.5-2". All the pics I've seen have the trucks looking pretty much dead level. I think they look great with just the Eibach springs. As for settling, I've only had them for about 800 miles and haven't noticed any yet. All springs settle eventually.
