Eibach Pro-lift springs installed with pics and comments
NEOGARAGE
North Royalton, Ohio
I’m thinking about the third setting with a drop shackle for the added weight capacity (but I don’t want it to ride like 1Ton either), and thinking about setting 2 with standard length shackle. I’ll probably start with level 2 and see how it does with the trailer and if needed I’ll add the leaf back in for option three, order new u-bolts and a drop shackle, and get limit straps (haven’t looked for these yet).
Like you said that’s the beauty of the Icon, you can change it.
It’s an enclosed trailer insulated and has a 40k BTU furnace, 4200lbs dry. Side by side is 2300 loaded for a trip plus other gear in the trailer. I have a picture with stock suspension and trailer hooked up, not sure I’m brave enough to post it on here though.
Not sure if this has been covered yet, but instead of doing the third setting and drop shackles, I would highly recommend the Timbren SES kit. I ran it while towing 7500lbs to Georgia and back to Ohio. They did the job flawlessly.
I wouldn't recommend the drop shackles just because as others have stated your limiting factor will be the shocks, brake lines, ABS lines, etc.
NEOGARAGE
So i have been following this thread and the references to Eibach Springs, Geisers, Deavers and Icons. Can someone help me understand the differences? I know I am opening myself up to criticism here but I'm a Newb when it comes this stuff but I wanna learn which is why I love this forum.
Hoping to the proud owner of new Raptor soon. Mine will likely be a pavement princess since there are limited off road options here in DC/MD/VA. However I love driving, don't mind long distance and I am exited to travel and join some of the events I see offered on this site. When I do get mine I want a smooth ride and the rear to be planted.
Eibach and Geiser springs are front replacements for the factory coilovers. Eibach is linear while geiser is progressive similar to factory. Both do the same job of lifting the truck, but the Geisers get smoother as they compress off road while the Eibachs stay at the same spring rate as they compress.
Icons and Deaver leaf springs are extremely similar, even made in the same factory, but Icons tend to have a better coating and give you the adjustability depending on your needs.
Slow6
AK
I plan to start with the second setting on the Icons and a new heavier duty shackle factory length to begin with. I do use a set of the super sumos when towing.
Edit 2 min after first post: I’ve been looking at the Camburg MIG shackles, are there any others worth a look?
NEOGARAGE
I think the Camburg ones are the best as far as a stock length shackle goes. You could get the TIG versions if you want really pretty welds and a better coating, but the MIGs are perfectly fine too. Both are much stronger than the factory cast shackles.
Slow6
AK
So other than @Obscure with his fancy pants spring compressor what have others used? I’ve found these two options. Shankly and Goplus 20inch
If I get the Shankly version I’d probably get two sets to cover my butt. If eibach fits in the goplus and people have positive experience with that being decent I’d go with that option. It looks to be a less sketchy finger mangling option with a fraction of the sphincter clenching required. Goplus max diameter is rated 7.8 inch diameter and 20 inch height.
What is the outside diameter of the Eibach and what is total height before installed/compressed and after installed on the Fox shock but not installed on the truck?
Only video on the goplus I could find:
Slow6
AK
Is that what you used? Everyone keeps saying you need something strong to compress the Eibach, I used to just pull them off and take them to a local guy and he’d swap the springs with the understanding I’d bring it to him for alignment. I’ve moved since then haven’t found a good place to make the same deal.
NEOGARAGE
That OTC one is really really nice. You can get the struttamer extreme that’s Wall mount and the amount of adjustability it has is insane.
OTC is a great company. I’d spend the extra dime for that clamshell one and not risk losing your head or other body parts.
