Educate me 500 Mile Range Claims for Gen 3
moog5050
Just filled my Gen 2 and it said 455. But I have been driving it all city recently.
Frank N
NJ and Outerbanks
The ecoboost isn’t your grandpa’s v8. Something I think it was @FordTechOne was trying to explain to me is that ‘the truck has to pull a lot of timing to run on 87, so when it’s burning 87 fuel it’s not running at its peak efficiency’ Maybe he can explain this a bit more eloquently, but I had run 91 pure gas and 93 w/ 10% ethanol in it, with about as same driving conditions as you could ask for without being on a track and the 93 did better on economy. It’s great that we have the choice in what fuel we can run.
If you think about it, what’s the break over point at which the per gallon cost increase of a higher octane level if you get less range out of a tank of gas and less performance. Yup, premium grade fuel is more expensive than regular and if that’s a deciding factor, maybe a truck isn’t the right vehicle.[
93 makes the beast come to life compared to 87.
I will run 87 when I have a 450+ mile road trip to the southern 'estate' lol...and throw the $35 saved at more beer. There is never enough beer on the beach.
GordoJay
Colorado
DTE will be too optimistic if you don't recalibrate your mileage calculation by recording actual mileage vs reported mileage several times, averaging the difference, and putting the correction factor into setup. I lost an apparent 6-7% when I did that, enough to drop reported mpg from 18+ to 17 and range from well over 600 to under.
TwizzleStix
Commivirginia
This ^^^^ If you haven't done the calibration procedure, your indicated MPG is significantly "wrong".
Reaper308
What’s this Fuel Economy you speak of? There are three things Full, Empty (or when you swing by the gas station) and the skinny pedal that makes me smile. Not so complicated after all we do own Raptors! It’s what they’re meant for.
GordoJay
Colorado
Mine's for going off road. :D
