E85 in a gen3
IronJay
Nebraska
So how critical is the change in pump E85 if we plan for the E50 blend? Pump can vary on E% depending on time of year and each batch. Do i really need to test tube each fill up or is there enough cushion in the tune of the E% is off a few points? I really don't wanna test tube each fill up, that's a pain in the ass!
If i stick with the correct E85 gallons per fill up I should be fine if I wanna run the E50 blend tune? If i have to test each batch of E85 i'll most likely pay for bigger injectors so I don't have to F with it!
Please post your experience.
Braaaaptor
Starbucks Enthusiast
The drive-thru
Anecdotally, my experience is that there's a decent amount of leeway in the tune (I'm using Goosetune). I have accidentally overfilled to about E60 and did not grenade my motor. Mind you, I babied it for about 50 miles and continually topped up to slowly lower that ratio. I believe Winfield states that the tune is safe between E40-E60 but so your own DD depending on what tune you use.
The above is the one horror story I have with E50 tunes. I tested my local pump twice (once in the winter and once in the summer) and saw no changes. If I'm going on a trip or otherwise find myself away from my regular pump - I use the same brand of ethanol for consistency sake. For me in Northern CA - Pearson Fuel has a huge ethanol pump network so for trip planning I use their app to find a Chevron and Pearson station. Using that method has been working for me for the last 3 years.
If you're constantly changing where you get ethanol or enjoy getting discounted or budget gas then it may be worth it to test what you're using.
IronJay
Nebraska
Thanks for the reply. I like what I hear about the E40-E60 range, that gives me enough leeway I doubt I need to test tube each fill. When I've run E85 blends in other cars I just consistently filled the tank around the same level and measure off of that. If theres some cushion I doubt I need the injectors.
GooseTuned
New Mexico
I did this 2.5yrs ago, was the first to test on E50 and tune it.
I ended throwing in 1050cc injectors and downpipes and made 552whp (others that came in to the game later even referenced me in their video and followed my build list ;)).
Ethanol adds a great deal of power, safely when tuned properly.
Our current Gen 3 raptor makes 630whp on bigger turbos. Should be making even more soon!
Let me know if you guys have any questions as it relates to E50. At this point I have more experience than anyone else tuning ethanol.
