wheelman55
I added the dual battery setup in the early summer of 2017 to my 2018 Raptor. It's been working really well for me.
This winter I added a ZAMP 180 watt folding system to keep the battery charged when I stay in the same spot.
Here's what I used for the dual battery setup:
Links:
Battery isolator
Wire, heat shrink, crimp connectors, and great advice
Harbor Freight - nutsert/rivnut tool
Track - I used the "wide contour" versatrack
ZAMP Solar - Back Country Solar - great service
Track install:
Mac's VersaTie Track in 18 Raptor
I used three 6' tracks. One kit of two tracks and fittings, plus one additional 6' predrilled track:
Track Kit - Surface Mount, Wide Contour (Series 3) - VersaTie
I added some M10 studs to attach the ARB slider and to attach the second battery behind the fridge.
M10 Threaded Stud
I skipped a hole on each track because the hole ended up right on top of the bed supports, leaving no access from the bottom to attach nuts. I drilled new holes in the track towards the cab end and decided to leave one hole out in the middle of each track.
Since I am OCD I'll go back at some point and either drill new holes or put rivnuts in the positions where the holes are over the supports.
Also on the OCD side...if you use a wide woodworker's countersink 82° Countersink - Lee Valley Tools you'll be able to mark the center of the new hole positions. The countersink that I used is wider than the access holes in the track so it centered for me. Then drill with progressively larger bits.
I installed the first hole at the tailgate end...I positioned the end of the track 5-1/2" from the tailgate end to miss the bed support. This placed that screw hole 6" on center from the tailgate end. Bolt the track down, then put another hole in at the cab end and bolt the track down. I installed the holes at the cab end 6" from the front wall of the bed. This cleared the bed supports at the front.
DRILL THE HOLE IN THE DRIVER'S SIDE CAB END VERY SHALLOW. I didn't and drilled right through the filler tube exactly through the band clamp that holds the tube to the rubber hose. I ordered the part and had the Ford shop do the install. It was a $300 boo boo.
Once you have your track secured at the ends, center punch the other holes. It is important to get these holes right in the center. I've got a set of transfer punches that matched the hole size, centering the position.
Transfer Punch Set - Lee Valley Tools
Then, without removing the track, drill a 1/8" pilot hole exactly in the center of each hole. Remove the track and drill the holes to size. I drilled mine to 5/16" for a small amount of wiggle room. The hardware is 1/4-20 stainless steel. No worries about galvanic corrosion as all of the surfaces are covered in paint.
Pics later today.
- Hellroaring solid state isolator.
- ARB Elements fridge.
- ARB slider. ARB Elements tie down.
- Battleborn LiFeP04 12v 100ah battery.
- Plastic battery box to hold the BB battery.
- Wire, crimp on connectors, heat wrap, clamps, heat shrink, etc. from Tony Candella/CEAuto Electric Supply.
- Anderson connectors.
- Mac's Tie Downs - tracks and connectors
- Pretty easy install as I had done one in my '93 F250.
- Mounted the isolator on the passenger's side firewall. Used nutserts in the aluminum firewall.
- Ran 8 gauge stranded wire from isolator to the bed. Installed a hole in the inside passenger side of the box near the top to run the wires.
- Installed the aux battery in the bed. FYI there is room next to the passenger side frame rail if you want to install the aux battery under the bed.
- Anderson plugs connect the aux battery to the new harness, and connect aux battery to fridge. Allows the battery and fridge to be removed when I need the entire bed.
- Mac's versatrack rails installed in the bed. I used three versatrack rails: driver's side, passenger's side, and #3 to the left of the passenger's side versatrack spaced to hold the ARB slider.
- ARB Elements slider attaches to the Mac's rails with screw on connectors.
- Battleborn LiFeP04 12v 100ah battery, in a plastic battery box.
- Made a simple cage to fit the bottom of the box with 1-1/2" aluminum angle, cut to size. Drilled holes in the corners of aluminum angles to attach to the Mac's versatrack rails. The aluminum angle cage attaches to the Mac's tracks, the battery box straps into the cage.
- ARB slider bolts to the Mac's tracks. Fridge attaches to the slider with an ARB tie down.
Links:
Battery isolator
Track install:
M10 Threaded Stud
Pics later today.
