KaiserM715
Kaiser Söze
Yes, I did. Yours always has power, and you have to remember to turn it off, right?KaiserM715, did you see where I brought power in on my install?
Nope. I left it in the cig lighter and it worked just fine.J, did you ever hardwire this setup for power? I am looking for ideas...
Hah nope, nothing so grandious. This ICOM's speaker literally booms out the voices. And the way I mounted it, you can see I'm letting the sound bounce off hard plastic; that basically had the effect of throwing the sound all over the cab. There was never a time where I couldn't hear well enough.BigJ, maybe I missed it, but what did you do for audio, with radio on floor and in the radio?? External, pump it through trucks audio!!
OSP
Correct.
Did you cut the dash or just pushed the wire through in between the panels? I am looking at mounting the head unit in that same location (currently running 50/50 with the location J used).I tucked all wires into slots in dash and console, under the rug and out thru the firewall.
Dan a bit more followup on your CB question.
Yaseu makes an $800 "mobile" (non detachable face) radio that supports HF as well as the other bands (CB freqs fall within the HF range). Some quick googling says this radio can be modded to Tx on the FRS freqs as well (although it looks more involved than the ICOM).
Yaesu FT-857D Amateur Transceiver FT857D
It does require two different antennas to operate correctly.
So that there would get you your homerun.
