Drone Killer
Gary E
Medford, Oregon
Never heard a true dual but I imagine it has a better tone than the corsa
Sent from my SM-G781U1 using Tapatalk
I don't know about the sound difference as I have never listened to or measured the Corsa's. I'd like to, to be able to compare them to what I have.
This thread is as close as there is to what I have. It has a sound video in it.
https://www.fordraptorforum.com/threads/stainless-works-lightning-exit-sound-test.60248/
It was done before the installation of the Helmholz resonator. I don't think a sound clip will capture any level of drone. Otherwise I would have done an interior one similar to the previous one.
The previous one didn't really capture the interior sound level. The db meter is what shows the actual difference. The meter would measure drone. Would need a frequency gauge for that.
bubbarob
DFW
Bumping this as I'm looking to do this in the next week or 2.
I find I have drone from ~1800-2200 rpm.
Do you choose the length based on when it starts? 1800RPM is ~27" j pipe
Gary E
Medford, Oregon
Personally, I'd go with the middle of the range, which is 2000 RPM. From my experience The Helmholz pipe will not rid the drone in the entire 1800 to 2200
RPM range, but it will help. The pipe can be added on to if needed.
Jakenbake
Just to add, and I don’t know this 100% for sure, but I believe you can run more than (1) j pipe. I “think” that corsa might do this.
Canuck714
Canuck714
San Antonio TX
Awesome, thank you both. Will go for mid range and see how it works.
I chose to target the start of the drone and wished I had of picked closer to the middle (1900 ish) as that was where highway speed/drone was the most obvious.
26 to 26.5 inches probably would have been a better spot for my truck, but I think this is all subjective to what system you run and how sensitive you are to the drone
bubbarob
DFW
Thanks for the insight, and agree. ~2100 is the worst point of the drone for me too. Will use that as the guidance for the length of J Pipe and see how it works out
Canuck714
Canuck714
San Antonio TX
You can always cut it an inch too long and then fine tune to the length you want once you run it.
I always said I would lop of some length on mine, but never bothered..lol
BalanBro
Just to throw another data point out there, I recently purchased a 2014 Raptor SCREW with the rear exit Roush exhaust, and the drone was unbearable. I was trying to figure out a cost effective solution and see what I could do with basic hand tools, and I may have found the answer.
Roush uses 3" piping, so I picker up the Vibrant Ultra Quiet Resonator (1142) and some lap joint exhaust clamps. I used one of those handheld "chain" style tailpipe cutters and cut out a section of pipe, slid in the Vibrant 1142 and clamped both ends. The result was a very noticeable improvement, but still a bit of drone.
I then called the Vibrant tech support line, and came to find out that the Vibrant 1103 "muffler" was constructed identically to the 1142 resonator, but was larger in every dimension (same pipe diameter though), and would be a more effective option. So I removed the 1142, cut off a little more pipe and put the 1103 "muffler" in place with the lap joint clamps. I'm happy to say that this pretty much did the trick, and the truck sounds quite tame under part throttle and cruising. It was a nice easy DIY job, and didn't break the bank, as the muffler was about $125, plus another $20 for the clamps, and maybe another 10-15 for the tailpipe cutter tool (you could also just use a recip saw with a metal cutting blade, although I think the pipe cutter leaves a cleaner cut). And the best part is no welding necessary, which makes this doable for nearly anyone with basic mechanical skills and tools.
