Spectragod
FL3Z-1626605-DAPTM is the chrome version
What is this?Good time to add an Anderson Powerpole.
You can create an adapter that connects to your battery and have the receptacle located some place that is easily accessible from out side the vehicle in order to charge or use the power from your battery.What is this?
You are correct.
So you're saying that you could just buy the cover (if it were possible to just buy the cover), paint it to match the truck color, and then simply remove the existing cover, and slap the new one in place, essentially covering up the lock hole?
I suppose that would be more convenient, because it would disguise the thief into thinking there's no lock to pick, plus it would also give the owner the possibility to still use the actual key (hidden in the key fob) by removing the cover. Is that right? Or am I misunderstanding something?
You don’t want to just replace the cover, you need to replace the whole door handle or disconnect/remove the lock cylinder if you are worried about theft as the OP intends to do.
Even if the door is locked you can still pull the handle out far enough to break in with a pair of channel lock pliers by twisting the lock cylinder. There’s videos out that show how easy it is to break into our trucks that way.
Downside is you do loose ability to get in if your battery dies but what does a locksmith cost to get you in for that one off incident? $50?
I think worrying about how easy it is to gain access to a locked vehicle is a waste of time. Having attended a school on lock picking and hot wiring, I can tell you that changing the lock isn’t going to deter the entry. Most thieves are only proficient on one type of vehicle and usually have several methods to defeat that vehicle. It’s not like gone in 60 seconds where a their is an expert at all vehicles. With that said, changing the handle might deter a crime of ease. but if they are there to steal our Raptor, unless you park it in a garage with the tires removed and a roving guard, the truck is gone. As for the crime of ease, don’t leave quick to grab stuff in plain sight.
