Fellow FRF members,
This issue started not too long ago and wanted to see if anyone else has experienced it and what other remedies you’ve found.
Long story short, driver seat on my ‘19 has slight side to side movement when turning. I did some research and found this post that has one remedy as well as the TSB for it…
Not looking to take it into the dealership cause the TSB is simply heat shrink and a clamp which can easily be done at home and seems more temporary than permanent fix.
Driver Seat Seat Shifting on turns - Ford F150 Forum - Community of Ford Truck Fans
2015 - 2020 Ford F150 - Driver Seat Seat Shifting on turns - Has anyone noticed the seat shifting every so slightly on turns? Mine does it usually when I turn right. It happens at least once on a trip and then doesn't seem to happen again. I had a similar issue on my 2012 mustang which seemed to...
www.f150forum.com
