R@pt0r
- Joined
- Jul 16, 2012
- Posts
- 75
- Reaction score
- 29
If you wire the cutout directly to the switch it will receive a constant 12 volts all the time, this will burn the motor out quickly. The cutout needs a momentary 2 second 12v pulse to open then a momentary 12v 2 sec pulse in the opposite direction to close. The setup worked but just wasn't reliable because the TR7 kept sending erroneous open and close signals. I suspect it was heat related. I'll always take reliability over flash so I mounted the rocker switch above the upfitter switches.
